rhagfo
Jan 12, 2017Explorer III
The box sub frame is done all the time.
First you really need to know exactly how much you need to raise the 5ermat the axles.
The best way I know of to do this is pretty easy.
1. Find a level place to do the measuring.
2. With 5er loaded as it would be to travel, and connected to the TV, then measure the height to the top of the bed rail from the ground at the pin. Call this measurement1.
3. Drop the 5er in that spot and level front to rear. Now measure at the pin the the distance to from the bottom of the overhang to the ground. Call this measurement2.
Now time for the math (measurment1 + 6") - measurement2 = amount of lift need at axles to be level. The 6" is the distance between bed rail and 5er overhang.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
