enblethen
Nov 20, 2017Nomad
As noted earlier, you need to get a multi-meter and test at the battery. You should while plugged in, see a healthy 13 volts. Disconnected, your battery level should show. Should be around 12.5 volts.
No 13+ volts then the converter or converter circuit may have issues.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
