time2roll
Nov 20, 2017Nomad
May as well remove the converter for a bench test. Assuming it is a WFCO I would replace it either way. But post the model number for best suggestions.
Do you ever camp off-grid and expect a fast charge from a generator?
YES charge the battery immediately. At less than 11 volts it is over discharged and sulfating. If there is a recondition or equalize mode use that too after charging. Battery plates can warp and cause a short when over discharged so good luck. At 6 volts you may need to jump start the charging to get the battery charger to even start working.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
