Shaft0201 wrote:
Dirtclods wrote:
I'll just add my 2 cents if your planning on running your heater you'll be better off running two six volts it's not hard at all to hook them up. I had two deep cycles 12 volts for years I so glad I made the switch it really makes a huge difference. Also if your lights are not already LED switch them out this to well save you batteries. I've never had an issue with Costco brand.
6v was a thought at first but I’m pretty stuck on getting two GOOD 12v batteries. As stated I have switched every interior light to LED, But thanks for suggesting. Will also be adding a voltminder and will order the better converter this weekend that has a smart charger setup.
Sorry my bad I skimmed through the part you already changed out your light to LED something else you can use to monitor your batteries if you have an 12 volt outlet on your rig.
https://www.rvupgradestore.com/Digital-Voltage-Meter-p/55-8167.htm?gclid=EAIaIQobChMIwcDlyLT-2QIVg0peCh0SgAyIEAQYBSABEgL6VfD_BwE&gdffi=d722fab84a06472899ce2a16e4d2ed3f&gdfms=5591832F4A54468EAF77E69DB7EB07AE
