HoganExplorerJun 02, 2014New pin box to replace demco glide rideI have a 2008 HHII 32.5uktg fifth wheel with a extended Demco glide ride pin box and a short bed 2013 f250 with a Pull Rite hitch mounted on standard bed rails. The problem is all the banging that g...Show More
kennethwoosterExplorerJun 02, 2014I agree if the tension bolt on the Pullright is out of adjustment you will get banging. Adjust and it should work fine.
Related ContentDemco Glide RIde pinbox discontinuedMor Ryde vs. Demco Glide RideDemco Glide Ride Pinbox showed upHydraulic glide outSlide "Spacer/Glide" Replacement
