transamz9
Oct 02, 2014Explorer
Cummins12V98 wrote:MTPockets1 wrote:transamz9 wrote:. 3400 is my pin weight, but my hitch weight is about 150, my tool box and contents are 300, two passengers 400, that's another 850, plus my 50 gallon transfer flow fuel tank, another 450 ... That's another 1300 lbs, plus I seem to recall the weight of truck fuel has to be added as well? That would be another 300 lbs. My Big Horn GVWR is 14,000 so my pin is close to 24%. We full time so we are packed. A 5vr with 16,000 GVWR is gonna go well over 3000 on pin, but if pushing 24%, closer to 3800 lbs, add to that the stuff in the truck and you'll be well beyond SRW label limits... Again, if using actual weights SRW is fine, but I'm just suggesting that people should stop guessing and hoping and go to the scales.MTPockets1 wrote:
I find the topic pretty interesting. Those convinced their SRW can pull anything will never change, when the 5th wheel topic is regarding "payload". An F250 can tow plenty, but the payload limit is less than an F350 SRW - and the payload for the SRW is less than the DRW. People must know their "actual" pin weight to know if their truck is properly sized. Too many guesses based on a percentage of their trailer GVWR. I "know" my pin weight (3400 lbs) and I know my truck empty and loaded weight, and I know a F350 SRW would tow fine, but would be overloaded. That's why I bought the DRW.... If you have been to the scales and know your total weights, and you are under your trucks payload label, then you have the right truck.
I "know" my SRW 3500 would not be overloaded with your 3400# pin weight. Been there.
Nice to see some people understand how to determine what tow vehicle is actually needed to safely tow a load with all the information included.
Thanks!
I find it hard to believe he raised his pin weight ratio 6% without going over his trailers GVWR.;)
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
