Cummins12V98 wrote:
fj12ryder wrote:
Cummins12V98 wrote:
ScottG wrote:
Run the trailer tires at their max pressure. You don't care how the ride is back there and running them at max means your getting max load capacity and less squirm so the tires will run more true.
I have tried all different methods and this strategy results in the most stable tow.
I would guess your tires need to be at MAX. With that logic do you run your TV at MAX on all 4 corners?
Are you running ST tires on your TV?
I only run QUALITY tires that can be inflated based on load, don't really care about the **** that is out there. I run the GY endurance "D" tires on my boat trailer and run them based on load NOT the 65 MAX.
I have MAXXIS on my MC trailer as the Endurance was not available then. I do run them based on load. If not my MC trailer would be hopping down the road.
With lightweight trailers like you've mentioned what you're doing doesn't sound unwise, but IMO there's a big difference between a boat trailer or motorcycle trailer, and a big ol' 5th wheel.
