Coach-man
Oct 11, 2014Explorer
It was mentioned, but maybe not clear, and at least inmy mind the pinweight needs to include the hitch which will be around 200 LBS. You should not have any dificulty in finding a FW to pull with a SRW 3500. But just incase, look for the FW that will fit your needs, check out thefloor plan, spend sometime in the units and imagine what you would bedoing while camping, i.e. If you cook, make sure you have room, and everything will work. Do not sell yourself short, what may be preceived as a minor inconviniance now could turn into a BIG problem down the road. Once you have selected the right FW, then check the numbers for towing, and buy what you need to tow with! Just my $0.02!
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
