hmknightnc
Aug 24, 2013Explorer
allen8106 wrote:
If the tank indicator says the "galley" is full then you likely have two grey water tanks. One for the galley "kitchen" and one for the bathroom. You just need to find and open the galley "kitchen" gray water dump valve.
If your galley indication is saying full then it is likely your kitchen 2nd gray tank is full. Your drain valve is likely on more rear portion of FW oppisite side of entry. Probably a pull cable. You should see a section drain connection with same type connector you attach your sewer drain hose too.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
