JIMNLIN wrote:
Dex66 wrote:
I found and spread sheet online and if I put the # in right for the Ram I should have about 1400lb. available for payload the truck won't have anything in it for weight. The ram has a payload of 4330 lb.
There is no Ram 3500 srw that can carry 4330 lbs in the bed as payload without blowing its 7000 RAWR number. That the fallacy of using newer truck high gvwr based payloads to assume a in the bed payload such as pin weight and other gear/stuff the rear axle will carry.
These size trucks rear axle can weigh in the 3200-3400 lb range. Now add 4330 lb of payload in the bed = around 7700 lbs for a 700 lb overload. Time for 19.5" tires and wheels and air bags/etc with that payload.
OP keep in mind that 4330 payload number is a gvwr based payload which comes from the trucks front and rear axles.
About the most the 3500 srw can carry in the bed will be around 3500-3800 lbs depending on cab selections....drive selections....wheel base selections.
Your starting with a 14k dry weight trailer. Now add 1200-1500 lbs of "stuff" and your looking at maybe a 15.5k lb trailer....maybe more depending on how much necessary junk :B you want to carry.
Your gonna' be close to max if you load lite.
I also agree 100%. We learned this the hard way ourselves. Upgraded to a SRW 350 from a 250 thinking we'd be all set to go (then and going forward), but bought a new RV and tho we ran the SRW 350 for a year w/o a prob, we were over on everything. Dry wt of 5er was 14,000 w/ max of 16k. Empty pin was 2900, fully loaded, pin 3750. Had almost 2k worth of "stuff" in 5er.
Yes we could have put bigger tires on, but fact of the matter, still over on everything else. Biggest concern to me is being over on tires and if in high temp areas along w/ high road temps, being over is asking for problems. Went w/ a DRW 350 and love it for towing. Yes I admit it may be a bit of a pain to scoot around town with, BUT don't regret it for towing the heavy RV. DRW stink in the winter, but just have to adapt and overcome.
OP, you asked for opinions and your getting them. If you think you want to get a larger/heavier RV and decide to travel, DRW is way to go. Think you said that you just plan on towing to CG from house and park it. IF and a HUGE IF that's all you plan to do, then a SRW will suffice. HOWEVER if you ever decide to want to do a lot of traveling, then DRW is in order w/ a heavy RV. Better to err on side of caution. Been there done that, in matter of 3 1/2 years.
