- ACZLExplorerLike others have said, any new of the new 350/3500 duallies will be more than capable of pulling the LM. No need to go w/ 450/4500 chassis.
- goducks10ExplorerMust've been a while since you've looked a diesel trucks since they all come with a 'Jake Brake' now.
Any of the 1 ton DRW will safely tow that 5th wheel. Test drive them all. They're different in their own way but all have the power and handling to tow your 5th wheel. - HalmfamilyExplorerThe F450 has a better turning radius than the F350. The F450 also uses commercial tires so will cost more at replacement. Same engine and tranny, different axles. Check insurance on F450 as some states as they may not be considered personal use.
- donn0128Explorer II
NorthernNeck,VA wrote:
It's 41 feet and heavy. I rode in a Dodge the other week and the truck actually came equipped with a Jake Brake. It is straining my current 05 F350 so I was thinking of getting a F450 if I go with the Ford.
NNK
New, properly equipped Rams can be rated up to 30,000 pounds. - 2oldmanExplorer IIIf you're made of money get a Freightliner Sportchassis M2 MDT. It's real nice to tow with a truck that weighs 6 tons. If you want control, comfort and safety, the heavier the better. If you mainly want towing power, the new pickups are fine for that.
- lee_worsdellExplorerMy buddy pulls his 41 ft landmark 365 with a new 3500 gmc dually . No issue lots of power
- NorthernNeck_VAExplorerIt's 41 feet and heavy. I rode in a Dodge the other week and the truck actually came equipped with a Jake Brake. It is straining my current 05 F350 so I was thinking of getting a F450 if I go with the Ford.
NNK - donn0128Explorer IIDrive, try each one out. Pick what YOU like best and can get the best deal on. Serious question for you, why a 450/4500? The current crop of 350/3500s should be more than up to the task of hauling all but the largest trailers.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 18, 2026
