8e3k0's avatar
8e3k0
No City Water Flow at Faucets
This problem is on a 2009 Montana 3400RL. Good city water flow and pressure to the 5th wheel but no flow to any of the taps or toilet. Can hear water flowing through a valve that is located in between kitchen cabinets and shower, this is the valve that is in behind and can be seen with a flashlight in behind the pocket door. If this valve fails, where does the water flow? No evidence of any leaks in or around the unit. When we run the fresh water pump all taps work with normal pressure.
To access the failing valve does one have to cut a hole on the back of the kitchen cabinets to replace same?
Any help would be appreciated. Thanks
