bigdipper94117's avatar
Oct 05, 2014
No gas to fridge and stove
2013 lifestyle 5th wheel. With full-side slide out. After we purchased the 5th wheel we set up a camp site at a resort in CA.
On our first time getting ready to go out on the road with it we discovered we had no propane going to the stove or fridge when we closed the slide. However, when we opened the slide back up, the gas came on. Trying to figure out the problem ourselves, we discovered the gas line was pinched under the slide. Now it has been in the shop for two months. We are getting exasperated! Has anyone experienced this kind of problem?
  • I think a call to the factory's customer service line is in order.
    The repair is taking far too long.
  • Did you take it to the selling dealer? Is it under warranty?
    Have you called the factory?
    Inquiring minds want to know
  • 2 months in the shop to change a gas line is a sure sign that the shop is not taking care of you! At the most I can not imagine spending more than a hour changing out a gas line. Sure it might take 2 hours to dis-assemble the floor and perhaps some time to get under the slide out, but still! 2 moths is un-acceptable.
    You MUST have a proper gas line. It should not be like the stainless steel gas line on your home water heater, as those are not designed to flex on a daily basis. It should be a rubber sort of hose, made to flex and move with the slide out. It seems like the factory design was not really good. It should have been protected better, and designed to flex open and closed 1,000's of times over 20 - 30 years before failure.
    Fred.
