If you have a multimeter and know how to use it (or take a fan or light plug it in to get a similar result).
 - Start at the shore power outlet. Does it have power?
 - Next plug in the shore power cord and check the far end. Does it have power?
 - Next check the breakers in the trailer. Are they tripped?
 - Ideally, you would pull the power panel out and check that power is getting to the panel and going out on each breaker but if uncomfortable, check if any of the household style outlets have power.
 - Trying the GFCI is an option.
You might also check the voltage on the battery. The odd thing is
 - The slide out should be running on 12v DC battery power.
 - The kitchen plug should be running on 120v AC shore power.
 - The fridge depends on the type. Some on 12v DC others run on 120v AC and some can use either.
Is there anything electrical that is running?
