moweepea's avatar
moweepea
no power
Hi all, I have a 25' Alpenlight, and all of a sudden I have no power. I plug it in and I can hear a hum but there is no power to anything. Also no battery power, and batteries are charged. I checked the fuse box and they all look good, is there a master fuse that I haven't found?Does it sound like a bad inverter/converter? Thanks ....
  • Unless your batteries are completely dead or shot, failure of both the 110Volt and 12volt sides of the electrical system is highly unlikely.
    Can you elaborate on what you mean by "no power"?
  • We had the same thing, my son did not plug in the 50 amp cord properly.
  • Check the master breakers near the battery. Check the incoming power at the pedestal, check the fuses and breakers at the converter. Get a VOM and learn how to use it. They are one of the best investments you can make for your tool box.
  • When you say "fuse box" are you including the circuit breakers?
