Romack's avatar
Romack
No Shore power?
So I'm no electric expert but I think this should be easy for someone that has half a clue...
New Road Warrior ready for maiden voyage was plugged in to 50Amp shore power in my shop. I unplugged everything and pulled it out to load it up ready to leave tomorrow. I plugged it back in and ... nothing. Fridge is full, gas kicked on all good. No 120v though. Start the generator and after about 30 seconds everything lit up but for some reason plugging it in to shore power is a no go. Fuse panel all on. Turned them off and back on, nothing. Off the read the manual but if anyone can help me before I pull out to go north noon tomorrow I sure would appreciate it.
  • 50 Amp is good, Also tried the 30 Amp outlet and the 120v regular outlet with adaptors and nothin in the rig. I'll read up on where to find said Transfer switch :-)
    Thanks!
  • Transfer switch.......
    You can get AC power from generator but not from shore power then transfer switch is first place to check for loss of AC power
    That OR 50A AC power in shop is dead....tripped breakers?
  • I guess I'll have to when the sun comes up. I plugged it back in the same place it was plugged in not an hour earlier!
    Thanks
  • Out with the meter...
    Is the power there where you plug in?
    Is the power at your panel?
    One or the other will point you to the problem.
