- Old-BiscuitExplorer III
Maintcpo wrote:
2 fuses on the board both good
F3 fuse is for the 120V AC
F1 fuse is for the 12V DC
Did you TEST fuse or just visual inspect?
Did you TEST fuse clips?
Any 'error' codes....?
ON LED ON and GAS LED Flashing?
L1 is 120V AC HOT lead
L2 is 120V AC Neutral
AC HT HI 1 is 120V AC HOT to element
AC HT LO 1 is 120V AC Neutral from element
120V AC between L1 & L2
120V AC thru fuse/clips
120V AC between HI 1 & LO 1 ----provided fridge is calling for 'heat cycle' (Thermostat calls for cooling...K2 Relay on circuit board Closes)
NO 120V AC to element...bad circuit board - Check for 120 volt output from the circuit board.
What is ID number on the circuit board? - MaintcpoExplorer2 fuses on the board both good
- There should be a fuse on the board. Have you checked it?
Bad relay on circuit board
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
