When I left the coach last month the frig was working fine on Auto AC the panel lights work, the fault code is F - A I tried to switch it to propane but no luck it won't fire. There is no apparent sign of leakage in the outside compartment. There is power too it,I used my multi meter in the outlet in the outside compartment it read 117 V same as the rest of the outlets in the coach. The fuses are ok I checked them with the Sperry multi meter. I called 2 different RV refrigeration repair company's in Port Clinton before I left to go home, one only works on boats the other does not make house calls. well I'm 150 miles from the trailer now I'll try again next time i'm up there. +
