Old-Biscuit
May 21, 2014Explorer III
macdaddy54 wrote:
to Old-Biscuit do you chk the gv and gv-grd with the wires plugged in to the board? unplugged or wires alone or just the board terminals? not much on electrical here!!!!! and I did run on 110 for two hrs and freezer at 30 and fridge at 60 not too good! ever heard of turning it upside down for a day then right side up to get ammonia stirred up after setting?
You check for dc voltage across those two terminals.
Ran fridge on 110V AC for 2 hrs.......freezer at 30*F fridge at 60*F
That's because the freezer section cools down first before the food section will begin to cool down.
2 hrs.......just getting started. Takes 4-6 hrs. for food section to begin cooling.
On initial cool down (AC or gas) it is best to operate it overnight to get properly cooled.
Tuning fridge upside down is an old 'band-aid' fix......an attempt to dislodge blockage which inhibits proper cooling. Blockage is a result of running fridge off-level causing poor gravitational flow, overheating/plating and that damage is permanent. It can NOT be cured by turning fridge upside down, rolling in end over end or any other gymnastics. The ammonia does NOT need stirred up.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
