lakeside013104's avatar
Jul 17, 2013
NORCOLD refrigerator not getting cold?
I have a new 2014 Bighorn 3685RL with the 12 cubic foot double sided RV refrigerator (NORCOLD series 121X). The first trip out the ambient temperature was about 70 degrees F. The frig worked perfectly. Second trip out the ambient temperature was 90 degrees F and the refrigerator was packed FULL for a 12 day RV trip. The frig worked perfectly. Third trip out the ambient temperature is 80 degrees F and the frig is packed medium full for a four day trip. The freezer is working perfectly, but the frig will NOT cool below 44 – 48 degrees F. I called my dealer and he told me to relocate the sensor located on the coil fins inside the frig. The new placement of the sensor has had NO effect on the frig temperature (still remains at 44 degrees F). I have run the unit on LP and then switched over to AC for several hours with the temp setting at #9 (coldest), with no change to the inside temp. Any ideas from other Heartland or NORCOLD owners on what I can try to get this frig working properly again? Thank you.
Lakeside
  • Fridge in a slideout.......are fans running in outside compartment?
    Also, a circulating fan in fridge section helps.
