Cummins12V98
Jul 19, 2014Explorer III
avvidclif1 wrote:
Several have made assumptions about the trailer weight, empty or GVWR. You need to look at the trailer placard and get the GVWR for the trailer. If it is the 13,360 you should be OK. Any higher and you could have problems.
NADA shows it to be a 2 axle trailer with a weight of 14,750 but doesn't indicate if that's gross or empty. Either way add an axle and you could be in trouble, weightwise with the SRW.
My 2 cents worth.
"Title weight" as the op said is 13,360# that is the actual stripped of any extras and water waste propane. so when you add all these things and personal belongings he would be a FOOL to think he could safely haul this RV.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
