mudrat025's avatar
mudrat025
onan 4000 watt no start
hello, i have a onan 4000 Watt whisper quiet in my hauler and when i push the start button at the generator i hear a click coming from the start/stop solenoid but no cranking.thinking the solenoid was faulty i put a jump wire over and still nothing.the even weirder thing is if i go to push the prime side of the switch it will only work sometimes??i am not good with electrical troubleshooting but know how to use a voltage meter...any help is appreciated!
  • We have the same genset, the first year we owned it we had a similar sounding issue. You could hear the solenoid click but that was it. Turned out to be a frozen starter motor, fixed under warranty, thank goodness.
    You do have to pull the unit out to change the starter.
    Good luck.
  • In addition to checking the battery voltage you should clean the battery terminals and grounds (including the generator ground). Also - in most rigs turning on the engine will connect the engine battery and chassis battery providing more juice to help start the generator.
  • I would agree with low battery or dirty terminals, would check that first.
  • How old are the batteries? Check battery voltage. Test to see if voltage drops dramatically when the genset starter switch is pushed.
