Diesel_Camper's avatar
Nov 07, 2014
Parking lot owner liability
In a separate thread I mentioned that I pulled our 5er into a horizontal sign arm in a parking lot. The damage was a hole in the fiberglass that came into the living area.
In any other situation like this I know it would be all my fault. This sign post was like nothing I have ever seen. It was located in the corner of the lot near the entrance. The horizontal portion stuck out from the main post about 6 or 8 feet and about 10 feet off the ground pointing straight out into the parking lot. The lot is on a corner and I was using it to turn around from one entrance and go out the other. I thought it was a lamp post and never saw the horizontal arm. There was no ballard preventing travel under the arm. I ended up turning the front of our 5er into it and didn't even know what I hit till I got out. Would the parking lot owner share any blame here due to an unusual structure with no protection to keep people from driving under it?
  • When you venture onto private property you're most likely driving VFR (Visual flight rules) so look around carefully.
  • sfpcservice wrote:
    .........The lot is on a corner and I was using it to turn around from one entrance and go out the other......
    Were you patronizing the business that owned the lot, or just using it to turn around in? Not that it likely matters since in both cases you hit a visible, non-moving object. But if you were actually a customer of the business, you might get at least some sympathy from the owner.
