I have a MagneTek series 6300A model 6345 I had called Randy and he sent me a PD 4655. it is a 55 amp. looking at instructions and it says not to install a larger am unit than you are replacing. ...
well I checked wire size at battery. has 2 wires, 1 6# 1 8#. thought 1 would go to converter but no. 1 goes directly to hydraulic pump for slides, other to the hydraulic jacks. where would the converter wire connect to battery. also does the shore power connect to the converter.
