goducks10
Mar 20, 2016Explorer
My pin box is 32" from center of pin to the end. My truck bed is 58" wide. So I have a 3" deficit. Or 1.5" per side. FWIW I have a 1716 style long pin box. I also have 6" of clearance between the 5er and bed rail. In 3 seasons and close to 10,000 miles I've never had an issue. The rear of the pin box is cut on a 45* angle and that gives me some extra clearance. The cut angle helps allows some of that 1.5" deficit to be useable. I make certain to watch when turning sharp. JMO but you need to look for a shorter pin box than the Lippert style 1716 if you want to be certain that the end of the pin box won't come in contact with the bed rails.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
