RussOnTheRoad
Apr 18, 2016Explorer
Dandy Dan wrote:
Russ, The newer trucks seem to have higher bedrails. I used to use a 2005 Dodge and had no problems at all. Got a 2014 Chevy dually and had problems. What I did was drop the pinbox 1 hole and had to trim the back corners off of the pinbox mount. Going to try this. Have a friend that had same problem and had to change pin boxes as he did get into the rail. Hope this will answer part of your question. Good Luck in the venture.
Thanks. I'm a little unclear, however. I've seen pin boxes that attach to brackets mounted on th rig. If I understand your meaning you must have such a setup. I've never worked with one of these but my expectation would be that dropping the pinbox down would in effect raise the rib because, after all, the pin and part of the box attached to it will always remain at the same height from the truck bed floor by virtue of the fact the pin fits into the hitch. What am I missing here?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
