George3037
May 21, 2019Explorer
Once you pack your supplies and put your toys inside all of the TT's you mention will probably be at or over the tow limits of your current vehicle.
I would suggest the 3/4T you mentioned. I have a 2016 2500HD CC 6.0 std bed with 4.10 gears and a WD hitch (which I suggest you consider buying). It will tow anything mentioned without a problem. My TT has a GVWR of 11,170 and I have no problem towing. The 3/4T will have far better suspension, brakes, handling, higher tow capacity than maxing out a 1/2T. I like the factory integrated brake controller too.
As far as the TT, the choice will be up to you as to what floor plan you like best.
Happy shopping.
Happy shopping.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 09, 2026
