ScottG
Aug 29, 2017Nomad
Never heard of a "compression block" but slides either have rollers or a strip of hard, (suaully white) plastic that they ride on as they come in. This piece of plastic spans the width of the slide and you can see it if you lift the flap of carpet at the front of your slide.
The front edge of the slide simply rides up on either of these two conveyances.
If someone has stepped on the unspported front edge of the slide floor while it is partially in, it can brake that long plastic guide piece. (at least that's how I broke one..) Then the slide will grind along the top of the floor and/or carpet.
I would inspect these parts carefully.
If the plastic guide is broken, you either need to have it replaced or even better, do as I did and modify the floor to accept rollers (BIG job).
About Fifth Wheel Group
