wandering1
Oct 11, 2013Explorer
That happened to mine and it was a bad “clutch gear” in the slide gear box. I had to put a wrench on the rod that went into the gear box and turn it till it “unlocked” and then the slide would retract. The wrench will be hard to turn to unlock the gear. Put a lot of pressure on it, you wont break it. There should be an access door on the bottom of the trailer to get to the gear box opposite the slide.
The gear box will cost a lot to replace if you get it from the dealer, contact the manufacturer that made the box and it is much cheaper.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
