GoPackGo
Apr 27, 2016Explorer
dedmiston wrote:
We have the 6 point Level Up system on our new toy hauler and so far I haven't been impressed. I spoke with Lippert on the phone and they said that it sounds like one of the sensors is faulty and that I should take it to my dealer for warranty service. The dealer is booked until late next month.
My two problems are...
Autolevel has never worked. It goes through of its gyrations and seems like it's almost level and then it nearly tips the trailer over to one side or the other. It's pretty scary to watch. Luckily it errors out and stops.
Also, the campsite has to be VERY level to even use the jacks in the first place. We dry camped at a pretty flat location last weekend and after extending all the jacks to the ground I couldn't level from side to side because of "excessive angle". The angle wasn't anywhere near as excessive as when the autolevel tried to tip it over. I had to pull up on 4" leveler blocks and get it nearly level before the jacks would operate. Why have autolevel jacks if you have to level the rig first?
I admit that it sounds like you have a system that needs to be looked at, but in the mean time have you tried to reset the system ? The procedure is in your manual. Basically you manually level it using the front/rear/side jacks and then tell it's brain this is the new 'level'. After that, when you hit 'autolevel', it should level your rig based on the new inputs.
I'm not saying this will absolutely solve your problem but since you can't get it into the dealer for a few months . . . .
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
