- janegowestExplorerWell...there must be something better than all manual...how do electric and hydraulic jacks work?
- laknoxNomad
janegowest wrote:
No, I guess I didn't express myself properly in my OP.
Since we are shopping used, most of them do NOT have auto-leveling, so I was wondering what else to look for, in terms of ease of use in leveling systems.
What all was out there, in terms of the older leveling systems and how much effort it took to use them.
If it doesn't have a system already installed, then you're back to the aforementioned "manual" system. Use bubble levels, either installed on the FW or somewhere on the frame, use some boards or "lego" blocks to level side x side, unhitch, then use the landing legs to level fore/aft. Pretty simple, just takes some time.
Lyle - laknoxNomad
janegowest wrote:
laknox wrote:
janegowest wrote:
We don't know much about the leveling systems in the 5ers. How many types are there? And how do they operate? we know that the auto-levels are just that, but the others, we don't know much about.
What should we look for in terms of the leveling system, if it does not have auto-leveling? What is the best type?
Thanks for your help in advance!
Jane, there are 3 basic ways to level a trailer.
1) Landing jacks (can be manual or powered) and boards under the wheels, supplemented by rear manual or powered stabilizer jacks in the rear.
2) Electric leveling systems. They use the front landing jacks and either jacks behind the rear axle (4 point system) or landing jacks and jacks in front and behind the axles (6 point system). Crudest are completely manual, but I don't think you'll find a manual system on anything built in the past few years; all are automatic.
3) Hydraulic leveling system. Same as electric, but uses hydraulic jacks instead of electric jacks.
For long-term parking, like a full season, jacking and cribbing the frame would be the best way to go, and most stable.
Personally, my next FW will have at least a 4 point system. :-)
Lyle
Thank you!! This is what I wanted to know!
Are these listed in the order of technological development?
Can't really say, Jane, 'cept that the manual stuff definitely came first! :-)
Lyle - janegowestExplorerNo, I guess I didn't express myself properly in my OP.
What all was out there, in terms of the older leveling systems and how much effort it took to use them. - buc1980ExplorerYou want the best ?Then 6 points Level-Up you need .
Lyle
Are these listed in the order of technological development? - dwayneb236ExplorerYep dedmiston, there is definitely something wrong with your system. So far mine has worked flawlessly. I could not be more pleased with it. Have only had to push autolevel and it goes through it's motions and it's perfectly level. First one I've ever had and cannot see not having one.
- GoPackGoExplorer
SabreCanuck wrote:
dwayneb236 wrote:
phillyg wrote:
I think 6-point leveling is the greatest thing since sliced bread.
What he said!!!!
x3
x4 I will not have another rig without it. - dedmistonModeratorWe have the 6 point Level Up system on our new toy hauler and so far I haven't been impressed. I spoke with Lippert on the phone and they said that it sounds like one of the sensors is faulty and that I should take it to my dealer for warranty service. The dealer is booked until late next month.
My two problems are...
Autolevel has never worked. It goes through of its gyrations and seems like it's almost level and then it nearly tips the trailer over to one side or the other. It's pretty scary to watch. Luckily it errors out and stops.
Also, the campsite has to be VERY level to even use the jacks in the first place. We dry camped at a pretty flat location last weekend and after extending all the jacks to the ground I couldn't level from side to side because of "excessive angle". The angle wasn't anywhere near as excessive as when the autolevel tried to tip it over. I had to pull up on 4" leveler blocks and get it nearly level before the jacks would operate. Why have autolevel jacks if you have to level the rig first? - laknoxNomad
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
