It appears the pocket door track between the upper and lower levels of my fifth wheel has come loose from the ceiling inside the wall. The Unit is a 2007 Open Road 357RL3S. It has a divided floor to...
I repaired a very heavy pocket door on a bluebird MH that has a mirror on both sides of the door.. Jack in Alaska had a MS fifthwheel and together we made a special drill holder and a lever action to remove the track and drill new holes and re screw the track and installed the door. It was a 2 man job and some thinking. Even had a length of string to work the drills switch. It can be done.
