larry_barnhart
Mar 09, 2016Explorer
schlep1967 wrote:
Go out to the end of the awning that has the motor on it. Have the other half push the button while you listen for the motor to run. On mine the motor was running but the end cap had stripped out. If that is the case you should be able to jam a piece of wood in there to make it roll up.
I fixed a neighbors with the problem you told about. Poor desigh or cheap metal on in the end cap. I drove a brass rod I flatten to fill the space at the flat area of the cap and motor shaft. Yes it was going to be windy so time was important. A pin though the motor shaft and the end cap would solve this issue.
chevman
About Fifth Wheel Group
