- mileshuffExplorerDometic had a recall on some of their awnings a couple years ago. Motor issues.
Reading the manual on mine mentions removing a screw and rolling it up. However, doing so damages something internal and the manual states it must then be serviced. - TucsonJimExplorer III'd suspect the switch isn't making contact if the battery and circuit breaker are good. You could try to pull the switch out and bypass it, or manually retract the awning.
- SoundGuyExplorer
kohana wrote:
So as evening comes on and the wind picks up your awning starts to rattle and jump. you try to retract it and nothing happens. 12v is good c/b is good now what?
Read your owner's manual which will describe how to manually retract a power awning. ;) - Artum_SnowbirdExplorerThat's a really good question.. tie it down as best you can for now.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
