Thumbs wrote:
Yeah I think thats the problem. Camco connectors. They aren't to expensive but I think thats the problem. Who makes better ones? Ha no cleaning these up. These boys are shot. One of the connectors came out od the cord connector and stuck in the pigtail.
If you have totaled up the amps you are drawing and are at, or under 24 amps when this happens, it could be the Camco Connectors themselves.
The heat had probably loosened the plastic that held the cord connector/terminal. We know travel trailer manufacturers often put low-spec items in their builds. This could be one of them.
Take the Camco plug to an industrial electric supply and see if they have a Woodhead, Hubbell or some heavy duty equivalent. Home Depot shows Leviton RV plugs but I'm not sure that's a good brand any more. Inexperienced or jackleg electricians often make a stranded wire connection in the wrong direction. Always make the loop that goes under the fastening screw in a clockwise direction.
