Whitley1981
Aug 22, 2017Explorer
Power issue
I had to replace a bad pigtail on my Keystone Challenger. My issue is I have no shore power afterwards. I and several other ppl have tested voltage. Power at pedestal, power at breaker , and even sho...
1995brave wrote:Whitley1981 wrote:
After checking again with a meter I have voltage from outlets hot to ground neutral to ground but none hit to neutral
If I understand what you are saying:
120 from Hot to Ground
120 From Neutral to Ground
0 from Hot to Neutral
You are then wired wring.
Should be:
120 from Hot to Neutral
