Casinojunkie's avatar
Casinojunkie
Power landing jacks
I have power landing jacks on my 5th wheel.
Just yesterday I noticed that the motor moves up and down and side to side when operating. Should this be happening? What is the fix if not. Thank you.
  • Mine wiggles.Check to make sure all the fasteners on the system are tight and then ignore the noise and movement
  • Yeah, that's normal. The motors are pretty free to move around due to the design, if you have a single motor drive with the cross shaft.
  • I think it is normal for the motor to have some movement. Mine has moved around since new, but works well, and is fairly quiet.
    Jerry
