dean1
Jun 27, 2013Explorer
We purchased a 2013 Prime time Crusader 355BHQ a year ago May. On the positive side, the unit tows very nicely using a Silverado 2500HD Duramax. It is an excellent floor plan for those who camp with kids and a crowd, We also love the outdoor kitchen. On the negative side, there seems to be quite a few quality issues that are not major but very annoying:
1. In the outdoor kitchen, there is a refrigerator. The refrigerator was secured to the wall with 4 brackets which were screwed into the very thin particle board. Needless to say, these pulled out immediately.
2. The outdoor drawer does not have any locking mechanism so it opens while traveling.
3. The referrer was placed directly on the wood without any kind of protection so it wearing away the wood.
4. Some of the outdoor seals are coming loose since they were only secured with 1 or 2 screws.
5. The water mixing value was set incorrectly so hot water was luke warm (fixed under warranty).
6. It seems that the sewer drain needs trailer movement to get it completely emptied. The result is when you open the cap, sewer water splashes on the ground. I added a valve to stop the splashing.
7. The microwave was secured with 4 screws through the metal/plastic trim. The trim started bulging and upon further investigation, the microwave was not sitting on any kind of support and only held in place with those 4 screws.
8. The drawer in the back bedroom can come loose which makes putting the slide out problematic since you have to extend the slide to get in the door to push the drawer back in.
9. The TV was wired to the sound bar with start video cables instead of using a nice HDMI cable. Additionally, the cabling was done incorrectly so that cable did not go through the sound bar,
10. Two tires failed (belts peeling off) after only 1 year of use. Not sure if this is normal or due to the inexpensive tires.
11. You will need a 90 degree fitting on the water connection as well as use a light weight coil hose so that you don't pull on the fitting. Otherwise it will leak. I put in the 90 degree fitting along with a quick disconnect fitting which works fine.
12. Back latter screws pulled loose within the ladder itself.
All of these are easy fixes, just a bit annoying.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
