BenbrookadExplorerOct 20, 2023Problems with electrical converterI have a 2015 Montana 3100RL fifth wheel. It’s began to blow the reverse battery protection fuses. I checked the battery connection and the white wire that is grounded to the frame is attached to t...Show More
nickthehunterNomad IIIOct 21, 2023Seems pretty straightforward to me. If everything is as you say, sounds like the converter is bad.
Related ContentElectrical problemElectricElectrical Problem - Converter?electrical problemsNo 12 Volt without converter
