stpettasExplorerMar 26, 2015Prodigy brake systemSystem is working. Worked for a while then I was able to use the manual lever, now nothing. Always reads n.c. Is there a way to check if its the wiring or the unit?
Campfire_TimeExplorerMar 26, 2015And check the ground wires. Nine times out ten, it's a corroded ground wire.
Related ContentProdigy Brake Control ?Auxiliary brake systemBest Toad braking SystemBraking system required?Braking system & brake buddy
