System is working. Worked for a while then I was able to use the manual lever, now nothing. Always reads n.c. Is there a way to check if its the wiring or the unit?
If I'm not mistaken the lever applies full power. So if there was a weak link in the system it would find it. Maybe fried a wire somewhere in the system due to corrosion, worn or loose connection, etc.
