parkmanaa
Oct 22, 2015Explorer
Can only help with the propane tank:
RV propane tanks are typically 30 lbs. Meaning at 80% of
capacity you should have 30 lbs. of propane.
If your's is the normal 30 lb. tank check the "tare weight"
on the tank's collar; add 30 lbs. to it, and you have an
accurate total weight, with that tank at the max of 80% full.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
