otrfun
Oct 26, 2015Explorer II
Txsurfer wrote:How many batteries (most TH's have 2)?
What is the estimated weight of batteries, full propane , and a generator? I assume that if you load all your cargo on or behind the axles these should be the biggest items that will affect tongue weight ( excluding the tanks )?
How many, what size propane bottles (most TH's have 2)?
Tongue mounted portable generator or OEM, cab-mounted generator?
Typically,
24/27 series batteries weigh approx. 45-55 lbs. each.
20 lb. propane bottles (full) approx. 40 lbs. each.
30 lb. propane bottles (full) approx. 55 lbs. each.
3500-4000 watt, portable, open-frame generators 100-140 lbs.
3000 watt, portable, inverter generators 80-150 lbs.
2000 watt, portable, inverter generators 45-60 lbs.
OEM Onan generators can weigh 200-300 lbs.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
