Nope. point the indicatoor to either tank 1 or 2. If you are pointed to tank 1 and it goes dry, the valve will transfer to number two if it is open and a red indicator should show. Change the pointer to #2 and it will show green again. Close #1 and disconnect and get the tank refilled.
There should be a manual for the transfer valve in the instruction book.
