abc40kids
Nov 22, 2018Explorer
Propane question
My fifth wheel has two tanks like most, if I put the knob in the middle and not right or left will it choose the full tank when the other goes empty?
padredw wrote:I close the valve on the empty tank when I switch the lever over to the full. Then I open the valve once I reinstall the recently filled tank. That way I know if the valve is closed, it's empty. If the valve is open, it's full. Otherwise, I'll forget.
The key point is to always get the empty tank filled as soon as you can after the automatic transfer. If you wait you may find yourself wondering, "Did I fill tank number 2 after I flipped that switch ?"
That's not a comforting thought on a cold night.
It work well IF you always get that empty tank filled immediately after the automatic transfer.
