abc40kids
Nov 22, 2018Explorer
Propane question
My fifth wheel has two tanks like most, if I put the knob in the middle and not right or left will it choose the full tank when the other goes empty?
TXiceman wrote:
Chris, Propane, AKA R-290. at zero pressure is -43.7 degF. At 0 degF it has a pressure of 24 psig, which is well above the 11 in of water column that is required to operate the appliances in an RV.
If you get so low, that the boil off is this critical, you can always put a 100 Watt light bulb in the compartment with the tanks.
