- Cummins12V98Explorer III
Bigmoss wrote:
Cummins12V98 wrote:
screw in a 1/8" MPT X 1/4" FPT then screw into that a Propane male connector with 1/4" MPT.
Cummings do you have a link to the part above ? I checked Amazon Canada and the US and it doesn't come up
Copy n paste these to AMAZON
ANDERSON METALS 756120-0402 Brass Adapter
Mr. Heater Propane or Natural Gas Connector Set, 1/4" Male Thread x 1/4" Female - BigmossExplorer
Cummings do you have a link to the part above ? I checked Amazon Canada and the US and it doesn't come up - Cummins12V98Explorer III
Bigmoss wrote:
Cummins12V98 wrote:
I removed my regulator on our Weber BabyQ and bought all the parts needed on AMAZON.
Unscrew regulator and screw in a 1/8" MPT X 1/4" FPT then screw into that a Propane male connector with 1/4" MPT. Use propane rated pipe dope.
At RV quick connect I added a "T" with two quick connects so I can run FirePit and BabyQ at the same time.
I have a 15' hose for BBQ and a 25' for FirePIt.
Now all I have to do is fill the BIG RV tanks.
Thanks thats exactly what I was looking for
Good deal, glad I could help. - Cummins12V98Explorer III
SteveB wrote:
Cummins12V98, what is the Hansen part number on your quick disconnect? I have 3/8" at my house and when I do the quick disconnect on my camper I would like to use the same size. It would be nice if the threads were 1/4NPT with the 3/8QD but I suspect I will need 3/8NPT to get the 3/8QD.
Bought them on AMAZON. Copy and past below. Looks like the price went up a couple bucks since I bought.
Mr. Heater Propane or Natural Gas Connector Set, 1/4" Male Thread x 1/4" Female - SteveBExplorerCummins12V98, what is the Hansen part number on your quick disconnect? I have 3/8" at my house and when I do the quick disconnect on my camper I would like to use the same size. It would be nice if the threads were 1/4NPT with the 3/8QD but I suspect I will need 3/8NPT to get the 3/8QD.
- BigmossExplorer
Thanks thats exactly what I was looking for - Cummins12V98Explorer IIII removed my regulator on our Weber BabyQ and bought all the parts needed on AMAZON.
- Diesel_CamperExplorerYou'd probably need to spend some time at home depot, but I'm sure you can find the fittings you need to remove the bbq regulator and direct feed it off the low pressure quick connect.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
