bbaker2001ExplorerNov 08, 2015propane ventingnoticed in the propane compartment there are 2 holes in bottom. also at top side is a 2" vent tube that goes about 28" to an outside vent at front of 5th. do I need a top vent with the 2 at bottom.
12 RepliesReplies sorted by NewestShow MoreeHoeflerExplorer IINov 08, 2015Propane is heavier than air, and will always fall to the lowest point, additional venting at the top is unnecessary.dbblsExplorerNov 08, 2015Most propane storage compartments are open in the bottom. I think you would need all the ventilation you can get.
Related ContentVenting Propane tankPropane furnace sending heat to outside ventNo vent hood over propane stovePropane Refillsmy propane generator won't start
