riltri wrote:
After talking to a few 5th wheelers who tow with SB trucks and own 5th wheels with the Turn Tec nose, I have decided to go with the Anderson Ultimate secured to the gooseneck ball.  A big change from the Companion fixed that I have been using.   Will also help with the payload that I'm close to maxing out as Lyle correctly pointed out.
Thanks again for all the help.
This is exactly what my brother did for his new RAM 3500 LB. Mine is a standard box (6'10") and I use an Andersen with the factory gooseneck puck.
Another advantage to using the Andersen is that (when installed in the conventional position) it adds extra distance from the pin to the truck cab further reducing the chances of making contact.
