Going through this now with a RAM 2500 Short Bed, moving to a RAM 3500 Long Bed.
Patriot Slider is set up on rails in 2500 SB.
The 3500 LB has pucks. BW only makes a puck adapter for the Companion.
BW Rep told me on the phone that Demco makes a frame adapter that the Slider will fit on, but it won't slide, because it sets too high.
If I was using a SB, I would have the rails installed and use the slider.
It costs $1200 to have a new rear window installed and the post repaired. Ask me how I know. UGH.
With a Short Bed, you won't need the Slider.....until you do.
